T56 leaking
Old Apr 25, 2023 | 02:47 PM
F350-TT's Avatar
Car: 89 Formula 350 CC1
Transmission: MD8
Axle/Gears: G80 GW6 J65
T56 leaking
Hey All,
I have a T56 leaking out of a hole in the extension housing. Photo below with a red arrow pointing at the hole. I stuck a rubber plug in it and seems to stop the leak for now. It's not a long term solution. I've searched and reviewed the T56 manual but not able to find out what the hole is for or why it would leak there. I've had thoughts of threading and plugging it with a bolt. I figured I'd run it by the forum to see if anyone has seen this before. Is something missing or broke?
Old May 9, 2023 | 12:29 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: T56 leaking
It's not a functional hole post-production. And should be a blind hole, which would not leak.
The pipe thread drain plugs work fine for fill / drain but are too big for that location.. A smaller version might work fine there, but verify thickness of the casting before threading.
Naga1337
Mar 7, 2008 10:37 PM
viperwsu
Feb 22, 2003 09:36 AM
Free Bird
Feb 24, 2002 12:02 PM
