T5 noises?
Old May 21, 2023 | 05:49 PM
Jayson_305's Avatar
Car: 1985 trans am
T5 noises?
Hey all, I have a question regarding my 85 trans am. It has a 305/t5… not sure if the t5 is stock or not. This noise only started today and I’m not sure what would cause it or why. It sounds like a very slight grinding or puttering noise, but goes away when you step on the clutch. Any help is appreciated
Old May 21, 2023 | 07:16 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: T5 noises?
Get it securely in the air and check the fluid level. Could be a throw out bearing too. I've also had rear axle issues that sounded like it was in the transmission area.
Old May 27, 2023 | 05:21 PM
shaynecastongua's Avatar
Car: 1985 Trans Am
Engine: Chevy 355
Transmission: T5 NWC
Re: T5 noises?
Another thing to check in addition to the above is the pivot point of the clutch fork and slave cylinder contact point. It's very common for T5s to make noise from that area though it normally sounds more like a chirping than a grinding. To test this get under the car with the engine running and the noise happening. Grab the clutch fork with your hand, if the noise changes or dies out then put some heavy grease (wheel bearing grease works fine) on the slave cylinder to clutch fork engagement point and also on the pivot ball for the fork. You can access it though the fork's cutout in the bell housing. Good luck!
9manastacio
Apr 2, 2011 02:10 PM
mooch1
Oct 25, 2010 07:48 PM
tyler86z28
Dec 23, 2009 07:12 PM
92camarors5spd
Sep 11, 2004 02:28 PM
