Neutral safety switch and "VIN E"
Car: 1990 LS6 Camaro
Engine: LS6 with a cam basically
Axle/Gears: 4th gen 3.42 rear
I'm doing an LS and an auto to t56 swap on.a 90 RS... According to diagrams posted in this thread and elsewhere, VIN E cars (TBI) have both auto and manual wiring for the neutral safety switch?
https://www.thirdgen.org/forums/interior/751381-neutral-saftey-switch-wires.html#&gid=1&pid=2
I have found purple and tan/white wires on both the auto shifter and another unused pigtail up under the driver dash. These seem electronically connected via a continuity test I did. Can I use either set? Will this work? How does this work and why only on VIN E cars?
Re: Neutral safety switch and "VIN E"
How does this work
It works because they are the same electrical point: you can plug a switch into either one, and it will complete the circuit. The wires that appear at the auto shifter are merely longer than the others, an extension, if you will.
Can't help you there. I'm not sure that's even correct. All cars with manual/auto options, where the auto has a floor shifter, use some variant of this. Not just F bodies, not just GM. My VIN 7 (83 L69) car has the same thing for example.
Car: '89 GTA
Engine: ZZ6TPI
Not sure why the VIN E would be any different than the others as far as a neutral safety switch. I've never seen a neutral safety switch on any T5 manual in an F-body. The neutral safety switch on the automatic shifter should be the same circuit as the clutch safety switch on the manual transmission setup.
