need some info......
Old Jan 22, 2002 | 04:48 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
I keep reading that if you want to bolt a 700r4 up to a pre 78 block(csb) you need to change the flex plate.....Well I put my 700r4 up to a 1967 327 block....it previously had a th350....I dont know if the flex plate was ever changed....everything seems to work just fine. this spring I am putting in a newly rebuilt 700r4 . The one I have now is dieing slow....I guess my question is..if I have the wrong flexplate ...would the tranny still bolt up and function??? What should I look for when putting in the new tranny as far as the flexplate goes...any info would be greatly appreciated....
Old Jan 22, 2002 | 08:17 AM
Nordbert's Avatar
It seems like some original equipment flexplates had a
bigger bolt pattern than a modern converter would bolt
to. Most flexplates I have seen come with two bolt
patterns, and I suspect yours is one of those. If it good,
there is probably no need to change it, but they can be
bought new for as little as $20.00 at :
www.northernautoparts.com
Old Jan 22, 2002 | 09:29 AM
bhaas's Avatar
What they meant was you can't use the flexplate off of a newer motor and put it on an older motor. What you have now will work fine.
Brad...
Old Jan 22, 2002 | 05:35 PM
Engine: 406
thanx guys..I didn't think there was any problem, But Hey I'm just a carpenter with a fast car!!!
Classicroute66
Aug 28, 2013 07:52 PM
procamaro85
South West Region
Dec 5, 2009 10:04 AM
Jaysz28
South East Region
Aug 10, 2009 09:39 AM
1988-305-tbi
Feb 26, 2007 05:32 AM
friskicouple
Mid-West Region
Apr 22, 2005 07:41 PM
