T56 Swap in an 88 GTA
Car: 1988 TransAm GTA, 1983 firebird SE
Engine: 350,305
Transmission: 700r4x2
Axle/Gears: 327
Currently looking at gathering the rest of the parts needed for my t56 swap. Im struggling with trying to find a proper crossmember. One that I was looking at was the "
BMR 3rd Gen F-Body T56 Torque Arm Relo Crossmember"
but it says that you must use the BMR full length torque arm as well. But BMR doesnt make a torque arm for a 9 bolt from what I have seen. Can i use my stock torque arm?Joined: Sep 2005
Re: T56 Swap in an 88 GTA
Don't think so.
Engine: 350,305
Axle/Gears: 327
Car: 86 Trans Am/85 K5 Jimmy
Engine: 406 FIRST/350 TPI
Transmission: TKO 600/700R4
Axle/Gears: 9Bolt/10Bolt front & back
Per BMR:
NOTE: DOES NOT FIT SOME 9-BOLT REARENDS FOUND IN CERTAIN 3RD GENS WITHOUT TRIMMING MOUNTS ON AXLE
UMI doesn't have any kind of note on their setups FWIW.
So it can fit, it just might take some minor trimming. But I can't see how a mount that fits 10 bolt rear ends wouldn't fit a BW 9 bolt as they are the same factory torque arms.
There might be some sort of "feature" on the 9-bolt pumpkin that their TA doesn't take into account somehow but the factory one does. Sounds kinda like an opportunity for some design improvement.
My 9 bolt has the adapter mounted to the bolt holes pushing the adapter furthest from driveshaft.
https://www.umiperformance.com/home/...acement-mount/
