88 Camaro Shifter assembly replacement
Old Nov 24, 2023 | 08:25 PM
Wackygreens's Avatar
Car: 1988 Chevrolet Camaro
Engine: 305 V8
Transmission: 4 Speed automatic
Hello, I am replacing the shifter assembly on my 88 Camaro. The plastic pin in the handle is broken off. I’m not able to find any videos to help with this. My concerns are mainly with the two cables that are attached. Are they under any kind of tension? Or can I just take them off of the old one and reattach to the new one. Are there any kinds of adjustments or settings that need to be done on the replacement or is it plug and play? Thanks for any help with this!
Old Nov 29, 2023 | 02:58 PM
thatsupnow's Avatar
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
Re: 88 Camaro Shifter assembly replacement
You could always go with a much better aftermarket unit. I had the same issues with my stock shifter and ended up installing a Hurst pistol grip shifter. 1000x better in every way
KrazyFirst
Interior Parts Wanted
May 16, 2012 02:48 PM
TADailyDriver
Jan 19, 2010 12:49 PM
88irocz28
Jun 13, 2004 06:13 PM
