Powertrax non-slip unit
Is anyone using the Powertrax non-slip unit, I'm not referring to the Powertrax lock-right unit that scrubs your tires when turning, but the newer one that is less noisy and allows turning corners. I had considered the True-tra, but it is a limited slip, whereas the Power-trax non-slip is still a locker.
Car: `86 SS / `87 SS
Re: Powertrax non-slip unit
What gear bias ratios were you finding available in the True-Track?
