T56 reverse too fast
Old Apr 2, 2024 | 07:02 AM
Mspangler's Avatar
Car: 1991 Camaro RS
Engine: 5.7 Lt-01
Axle/Gears: 3:28
I recently got a 1991 Camaro Rs with a Lt-1 5.7 out of a C4 corvette and a t56 6spd out of a C5 corvette with, I believe the stock, 3:28 rear gears. The car runs great everything's pretty fluid, but in reverse there's no going slow, like once it engages it like wants to go. This is only my 2nd manual vehicle so I'm not sure if it's just user error, or the rear end needs a gear change or thats just how these transmissions are? I know 1st 2nd and 3rd gear are pretty short as well.
Old Apr 2, 2024 | 07:53 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: T56 reverse too fast
Obi-Wan Kenobi: Use the clutch, Luke. Use the clutch.
If you want to back out of a parking spot slowly.... use small amount of throttle, if any, and slip the clutch to control speed.
Old Apr 2, 2024 | 12:01 PM
Mspangler's Avatar
Car: 1991 Camaro RS
Engine: 5.7 Lt-01
Axle/Gears: 3:28
Ok thank you, that's what I've been doing, just wanted to make sure it wasn't like major trashing stuff.
Old Apr 2, 2024 | 02:58 PM
pirateofms's Avatar
Car: 1989 Firebird
Engine: 2.8 V6
I was taught that you pretty much are never using every bit of reverse in a manual. light throttle, work the clutch. You're only going a few feet, not a few miles, so it's not much wear and tear.
Old Apr 2, 2024 | 04:54 PM
exiled350's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 427ci Gen 1 Small Block
Axle/Gears: Strange60 4.10 Eaton Truetrac
The only time I've ever fully released the clutch pedal in reverse in any vehicle is if I'm in the street and need to go more than a house length, or at my parents where the driveway is 75' long. Remember, gravity is your friend. Where I park at work I can pull through the spot and it's pitched enough to allow me to roll back right to the line without reverse at all.
Old Apr 2, 2024 | 05:37 PM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
^That^. You can let the clutch all the way out (if you're backing more than a couple feet), and just let the engine idle along, nice and low. 500 RPM.
That being said, ALL trans rev ratio's are too tall. IDK why...packaging, probably. But you could have a 5:1 rev ratio and that'd be totally fine. Only one time that I can think of when you need to actually USE the reverse ratio's that we're given:
Old Apr 10, 2024 | 06:23 AM
IndianaFoster's Avatar
Heheh, Use the clutch.
Spoiler
1gary
Jun 12, 2013 06:50 AM
89mulletbird
Southern California Area
Oct 13, 2012 06:16 PM
psmith757
Oct 25, 2011 02:04 PM
ssean92
Feb 5, 2006 10:56 AM
Scott C
Dec 22, 2002 01:26 AM
