Neutral switch B&M shifter
Old May 8, 2024 | 05:34 PM
Arnor's Avatar
Hi guys greetings from Iceland, I am trying to connect two micro switches to my Z-gate b&m shifter. I have connected the two middle wires(blue and green) to the reverse light microswitch but I am wondering if it is the orange and black wires or the thicker yellow and purple wires that go on the neutral switch, I have been reading that the orange and black is for the light bulb and the yellow and purple are for the neutral switch but also read on another thread here that the orange and black is for the neutral switch can anyone tell what wire pair is the correct one for the neutral switch.
Another thing should either the yellow or purple wire have power with the key on I measured the blue, the orange but none of the others had power(volts) with the key on.
Old May 8, 2024 | 05:49 PM
Re: Neutral switch B&M shifter
Yellow & purple are the neutral safety switch. Neither has power when the key is On. Yellow gets 12V with the key in Start, and passes it to the purple if the shifter is in Park or Neutral.
The others are the brake interlock that requires stepping on the brake to shift.
DuStangz
Apr 25, 2006 07:05 PM
link85x
Mar 25, 2006 09:12 AM
link85x
Mar 23, 2006 12:08 PM
Johnny Blaze
Aug 19, 2005 11:12 AM
KnightWarrior
Feb 22, 2005 07:39 PM
