LCA RELOCATION BRACKET DIMENSIONS
Old Nov 18, 2024 | 09:38 AM
jdogr62's Avatar
Car: 1989 Camaro
I'm trying to see if someone with a rear LCA relocation bracket installed can give me the dimensions of the LCA bolt hole. I am putting in a 9" rear end, and I want to make my own brackets on my CNC plasma cutter so I can have just 1 bracket instead of the stock & then lca relocation. I need from center of the axle tube to center of bolt hole both horizontal & vertical. This is a dirt track car, not a street car.
Thanks,
Old Nov 20, 2024 | 06:28 PM
thatsupnow's Avatar
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
Re: LCA RELOCATION BRACKET DIMENSIONS
Thanks,
Buy a set. They're cheap. Here is just one example. Many others out there
https://www.trickchassis.com/product...UE2_4j8msRvHxV
Old Nov 21, 2024 | 05:49 AM
jdogr62's Avatar
Car: 1989 Camaro
I want to make some thatare1 piece with no extra holes so that it looks factory. I have the technology, I just need someone to measure where the lca hole is in relation to the center of the axle, horizontal & vertical.
Old Dec 4, 2024 | 11:23 PM
CameronTate's Avatar
Have you started the work?
I am waiting for your response and till then I will search for a site online where I can find free essay examples.
Old Dec 5, 2024 | 04:15 AM
jdogr62's Avatar
Car: 1989 Camaro
Originally Posted by CameronTate
Have you started the work.
I have a design drawn up, I just need the correct dimensions to really be able to start with cutting them out.
Fendermender
Feb 16, 2023 01:02 PM
Der91Z
Dec 12, 2002 10:39 PM
89 Iroc Z
Oct 21, 2002 02:21 PM
tpi_roc
Dec 23, 2001 08:24 PM
