TH400 Valvebody/Governor Calibration Issue
Car: 1983 G20 Chevy
Transmission: 4L60
Hoping to find someone that really knows the TH400s valve body mechanically and hydraulically that might have some insight. I am trying to adjust the governor to allow for a ~5,500-6,000 rpm WOT automatic 1-2 upshift, I can manually 2-3 myself because it is seldom I make a 2-3 WOT upshift with a 3.08 gear as even 4,000 rpm is something like 85-90 mph. I modified a stock governor and there was as much as a 1,500+ rpm difference in the RPMs it wants to shift at on its whim. Bought a NOS L82/TH400 Corvette governor that should have been setup to shift about 5,500 with the lighter weights. Does the same exact thing as the governor I modified. Drives me nuts because sometimes it is 4,500, sometimes it 5,500 and other times it will hit the 6,000 rpm fuel kill. I put the stock 1987 TBI 305 governor back in and it shifts the same point every time for 2 weeks now. Just far too early, like 4,000 rpm. I verified the kickdown solenoid gets power everytime and re-adjusted the throttle linkage so it allows for actual WOT and the vacuum modulator should not be building much vacuum at all. I even looked at the hydraulic flow and it looks like in Manual 1st the 1-2 shift valve should have full pressure on the downshift side of it regardless. It has the same behavior when I tried a couple Manual 1st mercy shifts with the new Corvette governor. I do not understand how a new GM governor creates this issue but a 100k+ mile stock used unit has the same shift points consistently. Possibly related, it will not 2-1 downshift even with the shifter in 1st until it is under like 5-10 mph. No 2-1 part throttle or WOT kickdown at any speed either. Even rolling 10 mph it stays in 2nd. That being said the modified and Corvette governor both allow a part-throttle and WOT downshift up to maybe 15-20 mph, better but still nowhere near correct for a vehicle that will easily run 60+ mph in 1st gear. Problem with that is with the TH400s 1st gear and 3.08 rear gear it is already like some other transmissions 2nd gear and accelerating from 10 or 20 to 60 in 2nd gear is like accelerating in 3rd with other setups. Neither governor will allow the unit to make a Manual downshift to 1st over about 10 mph. My train of thought is that perhaps this 1987 unit that was behind a TBI 305 has a spring or two somewhere in it that is giving it this characteristic to comply with some kind of drive by noise decibel limit or emissions requirement GM contended with in the late 80s.
I think that is why I like the computerized transmissions like the 4L80E. If I cannot get this figured out, I think I will bolt a 4L80E into this before long and swap the rear end I have from a 92 G20 that has stronger 30 spline axles, 3.73s and a functioning G80. Might have to do something about that gov-bomb though before that rear end goes in.
~4,000 maybe 4,500 rpm manual low automatic upshift. Seems like it is exactly where GM would have made it for the TBIs powerband. Ignore the fan clutch stuck on, that is a problem for a different day. I know it is causing acceleration to drag a bit, but I feel unrelated to this problem, because the engine still pulls easily to the 6K fuel cut-off even with the fan drag when the higher rpm governor fails to make it upshift in time. This cammed Vortec 350 engine makes peak power at 5,500 and carries great power to 6,000 hence the reason the shift point needs to be raised and it needs a 2-1 downshift even at higher speeds when you want to accelerate hard. Some people are probably why bother, but I am tired of a 400 hp 350 V8 getting gut punched because it cannot get into the RPM range it makes its best power at or bouncing it off the limiter and having to lift to let it shift via modulator vacuum increase.
SRRF
Feb 13, 2010 09:21 PM
coprunr
Jul 15, 2004 04:07 PM
