Ideas on a LSD for an '83 Z28?
Car: 1984 Z28
Engine: chebby 3fiddy
How's it going,
Anyone have ideas on what I should do for my 83' Z28's differential? It currently has its factory open diff (10 bolt I think) , and im wanting upgrade to an LSD but don't have the first clue where to start. Ive been looking into getting a 4th gen rear-end and swapping it in, but have no welder for the modifying id need to do, and im not entirely a fan of the idea of the wheels poking out more. I do like the idea of having a disc brake set-up, and doing that would save time and money.
I think I saw a video where they bought a 4th gen rear end, took the LSD out of that, and found a late model 3rd gen with 28 spline axles and combined them into the factory rear end. Is this idea feasible?
The car currently makes around 400Hp, but ive got plans in the future for it to make a little more.
Any suggestions?
Any suggestions?
Re: Ideas on a LSD for an '83 Z28?
In a perfect world, the best choice would probably be to source either a used stock 4th gen Torsen or an Eaton Truetrac; gears of your choice which will depend on what transmission and engine combo you're targeting; the "LS1" rear brake upgrade to whatever 3rd gen rear; and better than stock 28-spline axles. I'd have the axle tubes welded into the carrier all the way around the tube, the factory's failure-inevitable plug welds that ALWAYS crack and leeeeeeek filled in, and LCARBs welded on, all this with some manner of fixture to assure that everything is straight and true. I'd get it powder-coated in some inconspicuous color NOT RED and add a girdle type cover such as from TA Performance.
Time was, the go-to would have been to start out with a 89-up 3rd gen disc brake rear as the core. Problem with that in 2025 is, parts for that disc brake system are disappearing FAST and some are now almost unavailable, therefore this approach is NOT future-proof. The 98-02 brakes will be FAR MORE serviceable for FAR longer into the future.
Car: 82 TA
Transmission: Magnum f
Axle/Gears: Ford 9 w 4.11
I think you can piece together a rear once you find all the ideal parts. That's totally an option. Other options are just doing a new carrier in your rear. If your at 400hp your on the line for a 10 bolt. I think it really depends what kind tires you have and how much abuse your gonna give it. Another option is one of the hawks drop in units or a drop in 9 inch. Those units are more capable of handling power but absolutely more work to instal/dial in. Sofa is totally correct w the scarcity of good parts and the situation w brakes. The drop in units often have modern brake options.
I have a "drop in" 9 inch. I used wilwood brakes on it. It was far easier to buy a 9in vs look for all the parts to build a weaker rear for a little less money. There are 8.8s and a few other drop in units at well. They are all larger than a stock rears so they need a little more stuff to make them perfect. The track bar relocation brackets/adjustable LCAs/adjustable torque arms are pretty mandatory once you jump to a different rear.
you could also just get gears/carrier and use all your stock axles/housing/brakes. That's the cheaper path but it won't last w a ton of abuse. I'm really happy w the 9in and would never spend my money/time on a beefed up stock ish rear. I've seen too many blow up over the years and really like beating on the car.
it's a tough call w tears in these cars.
Scoundrel
Mar 7, 2012 03:22 PM
89RsPower!
Oct 15, 2003 02:39 PM
