9 bolt or Zexel 10 bolt?
Car: 15 Ram, 88 IROC, 92 RS
Engine: 5.0
Axle/Gears: 3.42 (4th Gen)
I'm at a crossroads and have to make a decision on what to run.
I purchased a 3.42 from an 02 SS and put it in what I thought was going to be my build chassis. After chasing a title that never came, and finding more rust than I was willing to deal with, I purchased an 87 roller that came with a supposedly freshly rebuilt 9 bolt 3.27.
I built a TPI 350 backed by a 4L60e with a comp 268 roller, nothing crazy power wise. Which brings me to my question: if you were given the choice of both rear ends, which would you run? Especially knowing that it's likely never to see over 300hp?
Car: `86 SS / `87 SS
Re: 9 bolt or Zexel 10 bolt?
Does the width work with your wheels?
if Yes, does the limited slip work?
If yes, leave it.
I would open both. Verify ratio.
Verify if the 02 SS is a standard no-clutch-pack Torsen. Or SLP option HD Auburn.
It's highly unlikely the 9-bolt has a gear bias replacement carrier since that's imported aftermarket goods in N America. So it's open. Or it's cone clutch limited slip which can have wear problems.
89-up disc brakes are a positive, too.
If yes, leave it.
Engine: 5.0
The width of the 02 works beautifully, i love the stance with the wheels I have. I also rebuilt the 02 brakes, replaced the three hoses, and installed the proper parking brake cables. Both ratios are confirmed, and I resealed the 02 so I confirmed it was the Zexel design while I had the cover off. The 9 bolt has both calipers at the rear, so it has the 2nd design brakes, but I still prefer the 02 style and size.
I was already leaning towards using the 10 bolt and stashing the 9 bolt on stands in the garage. Thank you for your input!
91greenbird
Apr 2, 2007 05:32 PM
