Slip Yoke hep for part number on 88 GTA aluminum driveshaft
Engine: 355 TPI w/AFR 195s Dyno Don Headers
Axle/Gears: Borg Warner 9 Bolt, 3.27 gears
I have browsed threads but did not see. Anyone happen to have a part number for a slip yoke for a 1988 GTA with aluminum driveshaft. I errantly already bought a Dorman piece 697-557 that is incorrect.
Car: `86 SS / `87 SS
Re: Slip Yoke hep for part number on 88 GTA aluminum driveshaft
Use the info here to narrow down if you have an inside clip 3R or outside clip 1310 u-joint.
https://www.dennysdriveshaft.com/p49...nect_1310.html
Then if your driveshaft is 3R, get a 3R u-joint 27 spline yoke. Etc.
Thanks @jmd I will take a look at your info here and hopefully be able to get a replacement.
88fastgta
Sep 15, 2011 07:40 PM
