700r4 rebuild question
Old May 28, 2025 | 11:25 PM
kuhn_dawg's Avatar
I am currently rebuilding an 85 model 700r4. Upon case assembly I measured total endplay at the input shaft and found about 80 thousandths. I know the maximum spec is 035, my question is that is my tolerance too large to fix with shims? I have verified correct stack-up and believe all components to be compatible. The trans originally had a Sonnax sunshell with the torrington bearing and shortened low roller clutch race. This is my first time into a 700r4/4l60 so I did not recognize this. The low-roller was destroyed so I purchased a stock one; upon assembly I realized the stack up was too tall to install the output shaft. Since I already had the stock roller clutch I purchased a factory sunshell with the plastic thrust washer. It is only a driver with a bone stock 305 anyways. I have ordered a shim kit but the 80 thousandths of endplay worries me so I just want to be sure before shimming it. Thanks
Old May 29, 2025 | 04:58 PM
Pro Built Automatics's Avatar
Re: 700r4 rebuild question
Is this .080" with all the new parts installed? What number is on the shim under the bearing on the input drum?
When doing this check on the clearance. Leave out the reverse input drum and the 3-4 clutch pack. This makes it much easier to get an actual reading on the clearance.
Look at the area under the numbered shim and see if there is excess wear. This happens rarely but with excess wear here, you would need another input drum.
Old May 30, 2025 | 03:03 AM
kuhn_dawg's Avatar
The .080 was with the new parts installed. I have not yet replaced any hard parts or bearings other than the low roller and sunshell, as the trans was rebuilt about a year ago by someone else. I went ahead and reassembled the case again with the old low roller clutch and Sonnax shell to get a reading as I did not measure endplay before tear down. It measured .060”. I did take these measurements with the reverse drum and 3-4 clutches removed. The selective washer was number 89 and I did notice scoring on said washer. I will remove again in the morning and further inspect the input drum. Thank you for the input
Old Jun 1, 2025 | 01:28 AM
kuhn_dawg's Avatar
I’m unsure if this is a #68 or #89; as you can tell it has significant scoring. The input drum itself does not appear to me to be significantly damaged. The bearing does still roll very smoothly.
Old Jun 12, 2025 | 06:41 PM
ThatZ28's Avatar
Engine: 355
Transmission: Th200c
Hey I need some help with the trans in my 82 Camaro it’s leaking bad from this spot I think it’s the dip stick tube please help!
Old Jun 13, 2025 | 01:53 AM
It's obvious from the photo, you can see the top hat seal is out of position and tore up.
timonator
Jan 23, 2011 12:39 PM
discostu
Sep 22, 2007 01:32 PM
'89 Iroc
Mar 15, 2007 12:08 AM
fly89gta
Apr 6, 2005 07:52 AM
cwalsh
Jan 30, 2002 06:28 AM
