Factory speedometer gears
Car: 89 formula firebird
Engine: L03 with ported 081 heads/exhaust
Axle/Gears: 2.73 open
I apologize if this has been mulled over but I never have any luck finding exactly what im looking for sometimes in the forums. Im curious what an l03, 700r4, with 2.73 gears might have for factory speedometer gears
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Factory speedometer gears
https://www.thirdgen.org/forums/tech...libration.html
might
I think I’ve seen Vss gear charts on tgo
might
I think I’ve seen Vss gear charts on tgo Joined: Dec 2004
Engine: Lb9
Transmission: M20
Those 2 links were very helpful. I know that a 15 and 41 tooth setup will work for the 3.42 swap im doing. Just wanted to see if I had either of those already because yellow 41 tooth gears are getting hard to find for my particular vss (90-92).
Engine: 4++,350 & 305 CIs
I have a low mile set from a 92 gta. Had 305 tpi auto and aluminum drum limited slip 273 rear gear. Still have the rear and speedo gears.
Just as a reference, it appears that the gears i had in my car for 2.73 gears were a 38t and 17t.
