Hello, im removing the automatic shifter now but what do i do with the cable that goes from the shifter to the steering column, what does it connect to? (Right cable that's cut)
Reason: Clarity
Just remember, if you keep the auto column that while you can remove the cable the mechanism that locks the key cylinder is still there and can activate by rotating that section of the column. Just something to keep in the back of your brain. When I manual swapped my car I used the auto column for 20 years. Then I got a manual trans column rebuilt. Over the years i had the section rotate a little and lock the key in, it was really infrequent and as a result, 30 seconds of wtf. I feel like keeping the cable attached and zip tied kept it more stable and moved less.
