Poor Man Adjustable Clutch Master
Old Dec 23, 2025 | 07:24 AM
earlan357's Avatar
Car: 1987 Z28
Engine: 350 Vortec TBI
Axle/Gears: 10-bolt 3.73
I was tired of my clutch pedal’s high resting point and that stupid plastic bushing. Grabbed a Holley 4th gen master on clearance for $18. It has a rod threaded 5/16-18 RH. Threaded some 1/2” aluminum to adapt a 3/8-24 rod end. 1/2” of adjustment from stock, but the pedal ratio is 6:1 so can lower the pedal up to 3”. Used 3rdgenguy’s clutch pin. The rod is identical on the master side so I didn’t have to swap the master cylinder. Just had to pull the boot away to pop a circlip and work fast not to lose any fluid. Dropped the clutch pad even with the brake. Not bad for about $70 all in.
Holley 82-609 4th Gen Clutch Master
3rdGenGuy Clutch Pedal Pin
cubby-5056
Dec 23, 2025 09:19 PM
spicyskater
Feb 12, 2015 11:25 PM
TennesseeIroc-Z
Mar 22, 2013 10:38 PM
spodeboy
May 10, 2003 10:34 AM
