New noisy Tremec 3550 trans
Old Jan 25, 2002 | 08:00 PM
Scottlb9's Avatar
Car: 1991 Formula
Engine: 5.0 TPI
New noisy Tremec trans
After a year of fighting for parts, looking for quality mechanics in the New York area, and my fiancée joining the NAVY, it’s my time now! Problem is, my new trans makes a rattling noise, like a bolt fell out and is bouncing around, after it warms up and in 5th gear.
Also, if I stab the throttle while it’s cool, the same sound occurs but only for a split second. Anybody have any ideas? Bent input shaft? Bad bushings? Bad install?
Also, any good shops in NY that have a decent idea of third gens?
Thanks!
Old Jan 26, 2002 | 09:08 PM
Scottlb9's Avatar
Car: 1991 Formula
Engine: 5.0 TPI
I forgot to add that when I disengage the clutch, the noise goes away.
Old Jan 26, 2002 | 09:15 PM
Yvonne's Avatar
Have you talked to Andris Skulte? www.skulte.com . If you can make a 2-hour drive to PA, Art could take care of it. www.rearman.com . Be careful - I found so many risk businesses in NY, that I will not do business with any until referring to my research results. I have no intention of getting stiffed or selling stolen parts!!!
Old Jan 29, 2002 | 06:48 AM
'91 Formula's Avatar
Car: 1991 Firebird Formula
Engine: 383 Supercharged and Intercooled
Transmission: 6-Speed
Axle/Gears: Stock 10 bolt 3.42
What clutch do you have? I have heard of the CF weights coming loose.
Old Jan 29, 2002 | 09:04 AM
Scottlb9's Avatar
Car: 1991 Formula
Engine: 5.0 TPI
I have the CF 1 and it's really more of a grinding now. Could the input shaft be a little bent? There is a vibration in the stick which is noticable in third and most noticeable in fourth at about 1600 rpm. Above that, it's noticeable but not as much.
1992 Trans Am
May 10, 2023 07:19 PM
Hawk312
Aug 22, 2017 08:55 PM
Hello, Michael
Aug 20, 2015 03:19 PM
mizz0313
Aug 12, 2015 06:45 AM
Leggman1
Aug 6, 2015 04:15 AM
