whisling from clutch
Old Feb 10, 2002 | 06:41 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
hey guys i just put in a new clutch.pressure plate, pilot bearing, throwout bearing, and got the flywheel resurfaced. now that its all together my throw out bearing make a whisling sound but and soon and i toush the pedel it goes away then if i let off again its still there. is this a bad bearing or what? thanks
Old Feb 11, 2002 | 02:11 PM
Fastcamaro87's Avatar
well you are not alone, i just put a new clutch in my 87iroc, and my buddy, put one in his 89iroc, both of our cars make the whistling sound, and as soon as you touch the clutch pedal, (maybe move it 1/2 inch) it stops, it`s really annoying, im not sure if this is just because it is a a new clutch, and maybe everything will wear in and it will stop, or if there is a problem with the T/O bearing if you find out,let me know , also what kind of clutch are your running?
before i changed the clutch i am pretty sure i did not have this problem, and the clutch i just put in was the same brand as the last one. I replaced everything because i rebuilt the motor.
BTW : the clutch is a ZOOM Powertorque, matched set.
Old Feb 11, 2002 | 02:41 PM
Car: 89 Formula
Engine: Carbed 5.7
i just put a stock clutch in i got from pepboys. i think i was a lucas or sumtin like that. i have tolked to the guys over at thirdgenresourse and they said that it has happened to them also and wut they did was change the throw out bearing and it was fine. they said go with an all metel one and not the plastic ones. I am just hopeing sum1 else knows how to fix it without dropin the tranny cause i'm not lookin forward to that
Old Feb 11, 2002 | 02:43 PM
Car: 89 Formula
Engine: Carbed 5.7
by the way how do u liek your lt1 cam? is it lopey or does it just sound stock
Old Feb 11, 2002 | 04:45 PM
really, i wonder where u can even get an all metal one, because the plastic one is supposed to be the new design since it doesnt need greased, i think im gonna leave mine in there until it stops or until it pisses me off enough to drop the trans, one thing i thought abput doi is, takin a throttle return spring and hookin it to the clutch fork under the car , with just enuff tension to keep it depressed that 1/2 inch, so it doesnt make any noise
as for the LT1 cam, im pretty happy with it, it has just enough lope to let you know it aint stock, but run smoothly enough to pass as a stock one to the unsuspecting,im not real sue about how hr ts gonna pull at the upper RPM`s since the motor only has 125 miles on it, and its not broken in yet, so i been keepin it below 3k, but it really screams with all the mods i did.:lala: :lala:
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
Night rider327
Sep 2, 2015 04:18 AM
