My T-5 won’t go in first gear
Old Feb 12, 2002 | 11:26 AM
V8RX7com's Avatar
From: Peoples Republic of California (Los Angeles )
I recently installed a used T-5 (in my RX-7 with a L98) I’m using it with a Hurst shifter that I purchased. My problem is:
First gear is hard to find. All other gears engage fine. It will go in first only sometimes, and it works fine when it does. I’m trying to figure if the problem is with the shifter or with the transmission? I don’t have the stock shifter, so I cant swap out the shifter without buying another one. Any advice on what I can try or do, to locate the source of my problem? Thanks.
Old Feb 13, 2002 | 06:00 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
You should be able to take off the shifter and try changing gears with a large screwdriver. I'm not sure if you can do this with the tranny in the car though.
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
georgiaslim45
Sep 9, 2015 08:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
