re: rear gears
Old Feb 15, 2002 | 05:11 PM
rokkgod's Avatar
re: rear gears
how can i tell what the rear gear ratio is in my 1992 305 z-28?
Old Feb 15, 2002 | 08:19 PM
idrag2's Avatar
Pull the cover off the back and count the teeth on the pinion and ring gear and then divide them togeather........most ring gears have the tooth count stamped on them....
Old Feb 15, 2002 | 09:11 PM
pokes87iroc's Avatar
if u take and write the 3 digit codes down on ur consloe lid u can type it in on this site under something codes and it will tell u everthing u want to know
Old Feb 16, 2002 | 12:02 PM
92blackZ's Avatar
Car: 1992 Z28 camaro
Engine: 5.7
gear ratios
Look under the hatch on the drivers side and there is a locked compartment.Write the codes down and then go to the vin decoder section. It will tell you the gear ratio and everything else about your car.
Old Feb 16, 2002 | 04:20 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
The RPO codes can also be found under the console lid.
And the easiest way to check your gears, not perfect but very close. Is do 70mph in D, look at your tach, if it reads 2730rpms then you have 2:73s and so on.
Old Feb 16, 2002 | 06:01 PM
transfixleo's Avatar
See: https://www.thirdgen.org/techbb2/sho...threadid=84852
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
Jlanz55
Aug 17, 2015 07:15 AM
mizz0313
Aug 12, 2015 06:45 AM
