Centerforce
Centerforce
Does anyone have a centerforce clutch in there car? My cars clutch is gone and I'm going to replace it real soon. I also need info on a good flywheel mines toast. What centerforce should I use the dual friction or the "LMC series"?????
Car: 85 iroc,96 z28,96 Ram 2500,69RR
Engine: 383 with AFR heads.
Transmission: richmond 5 speed
Axle/Gears: 1991 w/1LE.auburn pro series.2.73's
one clutch or 2 or 3 usually dont toast flywheels-do you know that machine shops can turn them so they are as new? like a brake rotor-same theory-totally different machining operations-you get it. unless yours is transparent there is probably hope for it. also if the ring gear is lookin worn it too can be replaced-us cheap bastar-s flip it over to squeeze that penny till its just screaming.
BOWTIROC
Aftermarket Product Review
Jul 12, 2001 05:57 AM
