400 Out Of 350
Old Feb 17, 2002 | 06:23 PM
grumpygreaseape's Avatar
Car: 85 iroc,96 z28,96 Ram 2500,69RR
Engine: 383 with AFR heads.
Transmission: richmond 5 speed
Axle/Gears: 1991 w/1LE.auburn pro series.2.73's
400 Out Of 350
i just go this today for xx.00 dollars and i am not believig it myself. what you cant see is the 153 tooth flywheel and used centerfarce clutch. i did a little searching but found nothing for sure-so-has anyone ever gouged out a MANUAL transmission flywheel (not flexplate-done it already)off of a 350 and attained the imbalance required for a 400? with or without mallory metal? is it cost effective? i am going to have the balance shop zero balance my clutch and whatever direction i decide about the flywheel-even if i buy a new one for a 400 it is getting balance matched to my flexplate anyhow, so if the rest of the gouging procedure is cheap enough, why not? :lala:
Old Feb 18, 2002 | 01:36 AM
ok ttt- xx= 50 for all of it. putting bearings and synchros tommorow nite.
Old Feb 18, 2002 | 05:55 PM
balance shop in reseda =no problem. 75.00 including the balance match to old flexplate.
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCtometal
Sep 2, 2015 02:01 PM
