Best Master Rebuild Kit for 700R4 ?
Old Feb 18, 2002 | 11:00 PM
whiteroc's Avatar
Who sells the best and least expensive master rebuild kit
included steels and frictions for the 700R4. This is for an 89
IROC-Z but would rather have the kit made for the Corvette of
the same year. When I say least expensive I mean under $400.
Old Feb 19, 2002 | 02:59 AM
Pro Built Automatics's Avatar
If you are looking for the highest quality kit?, then go to my website www.pro-built.net I offer complete kits and or parts for anything demanded of the 700R4! Let me know if I can be of help.
Old Feb 19, 2002 | 07:28 PM
whiteroc's Avatar
Your prices seem a bit high for a rebuild kit. What's the difference
between the parts you sell and the others that have them at
much cheaper prices?
Are there any other rebuild options besides what you show
on your site?
Is the Torque Converter included?
Rebuild Kits
GM 700R4
Products 700R4 Rebuild Kit-Heavy Duty $468.86
700R4 Rebuild Kit-Street/Strip $531.73
700R4 Rebuild Kit-Road Racing $527.84
Old Feb 20, 2002 | 10:09 AM
If you compare the kits that I carry, they are complete kits, with all of the updates and no questionable clutch/band material. I add the turbulator steels, Viton input/output shaft seal, Teflon bushings, special pressure regulator valve, etc. This is not a generic rebuild kit with a couple of minor changes like you see out there. If you compare apples to apples, you will see over a dozen changes/updates when compared to other rebuild kits. This is a "complete rebuild kit" with the additional hard parts offered if needed or desired. If I can be of service, let me know?
Old Feb 20, 2002 | 10:56 AM
Nordbert's Avatar
Have you checked www.otsparts.com in OKC? They will sell to
individuals as well as commercial accounts. 1-800-288-3668.
Or www.northernautoparts.com 1-800-831-0884?
Old Feb 20, 2002 | 11:21 AM
KiDKiD911's Avatar
I can get a Transtar master 700R4 overhaul kit (bearings, bushings, borg-warner clutches, filter, band, etc) for $115 through NetGearHead. Email Corey at sales@netgearhead.com
Old Feb 20, 2002 | 09:37 PM
ryn28's Avatar
Car: 1986 Camaro Z-28
Engine: Chevy ZZ4
Transmission: Select Built 700R4
Axle/Gears: Moser Axles / 3.73 Richmond Gears
I've had tranny problems before. Do it right the first time or you'll be doing it again alot sooner then you expected. Sometimes it holds true in "you get what you pay for".
New2Chevy
Sep 28, 2015 12:35 AM
greenyone
Sep 2, 2015 03:39 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
masonta
Sep 1, 2015 06:40 PM
