Found this shift improver kit for $20.99 part#K61908j or this on part# K61908 for $36.99 it contains servo,accumulator, governor and valve body parts. They can be found at www.northernautoparts.com would one of these be worth the money?
Here's the page to make it easier.
http://www.northernautoparts.com/Pro...ctModelId=5285
It's not a transgo kit.
and it says SHIFT IMPROVER KITS TransGo (R) No Yo YO (R) Fixes the problem that causes transmission failure IS this false advertisment?
Hey, I have to sleep sometime!
OK, I went to the catalog and it is a little confusing. Where it says transmission shift kits it does lead to TransGo BUT, it says TranStar as manufacturer. They are a supplier to the industry and do not sell to the general public. Also, the specified kit is for professioal use. If you think that the Reprogramming Kit is confusing you sould try this! You will be lost and it won't be of much help since it assumes you know what you are doing. It is also NOT the HP/HD kit, as the Reprogramming Kit is.
