Adjustable Driveshafts?
Old Feb 24, 2002 | 09:32 AM
427camaro's Avatar
Car: 05 Nissan Xterra
Engine: 4.0L DOHC
Transmission: 5 Speed Auto w/ OD
Is there such a thing? If so, where can I get it?
Old Feb 24, 2002 | 11:02 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
i've never heard of an adjustable driveshaft. Why would you want one?
Old Feb 24, 2002 | 01:08 PM
427camaro's Avatar
Engine: 4.0L DOHC
Mainly because I'm swapping out the 2.8L(173) for a 7.4L(455) and swapping the 700-R4 for a THM-400. Therefore, the driveshaft is going to have to be shortened. So I was just curious if there was one. I thought I saw one in Jegs, but looked and there wasn't one.
But hey, an adjustable driveshaft is a good idea for someone to be working on.
Old Feb 24, 2002 | 02:59 PM
kevinc's Avatar
Car: 1982 Z28
Our old International Harvester tractor had a 2-piece splined driveshaft that could vary length. It had a max speed of 10mph tho.
Old Feb 24, 2002 | 07:36 PM
Bob86ZZ4's Avatar
There are shops that can shorten your driveshaft and re-balance it. I live in MN. and there are a few around here. Any big metro area should be able to do the job. Look under u-joint places. I'm going to be taking my driveshaft to a place hopefully tomorrow to have it shortened once I get my th400 and gear vendors bolted together and measure the difference from my 700r4.
Old Feb 24, 2002 | 08:15 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You're going to need more than just shortening; the Turbo 400 has a different output shaft size & spline from your 700.
Lots of things have driveshafts with splined sections in them. The front ones on most 4WD trucks are like that. It could be added to a car shaft but would be more expensive than just having the right shaft made up.
Old Feb 25, 2002 | 01:08 PM
427camaro's Avatar
Engine: 4.0L DOHC
Hey Bob, what are you doing, just replacing the transmission or are you replacing the motor and transmission?
And RB83, I have a yoke that will work. The motor and tranny came previously out of a 70's camaro, I know it will work with my '88. I'm pretty positive, it will. I'm not being mean, but I'm just saying.:hail:
InfernalVortex
Apr 20, 2021 11:31 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
