how have ur 9 bolts held up
Old Feb 24, 2002 | 03:04 PM
Spindr130's Avatar
last summer i had to rebuilt my 9 bolt after blowing the pinion gear. i put the rear in my car and well ever since i have been really worried about playing with the car (the fun stuff power brakes donuts and such). so i am just wondering if have the rest of 9 bolts been holding up.
Shaun
Old Feb 24, 2002 | 04:12 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
When I still used one I was running high 11's with no problems.
Old Feb 26, 2002 | 02:29 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Mine has held up to 7.76 1/8 mile passes with 1.72-1.75 60fts, plus tons abuse on the street.
What actually broke, the pinion or one of the 4 pinion gears? and how did you rebuild it?
Miles
www.9bolt.com
Old Feb 27, 2002 | 01:08 PM
Spindr130's Avatar
Well on the pinion gear I broke about 4-5 teeth clean off and chipped the hell out of my ring gear, cracked the housing. So I bought a rebuilding kit.. bearing and such. Bought new gears 3.70 a total of 450$$ i beleave and my father and i put the rear together we checked all the things back lash and wat have u. we preload the crush collar. It took about 3 to four weeks. I am going home at the end of March and will take pic of the pinion gear and show u want happened. We also welded the crack shut.
shaun
Old Feb 27, 2002 | 03:18 PM
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
When you say pinion gear I am assuming you mean the pinion (which meshes with the ring gear). The pinion gear is actually the 4 smaller gears (also known as spyder gears) that mesh with the axle gears (also known as side gears). A stripped pinion is usually the cause of a bad pinion bearings, too much pinion depth or loose carrier bolts. From what it sounds of your setup, a properly setup 9 bolt should be just fine.
Welded what crack back together?
Miles
www.9bolt.com
PS The 3.70 gear is not as strong as the original 3.45 was.
Old Feb 27, 2002 | 05:38 PM
Spindr130's Avatar
See the houseing where the crack was (aprox 1" long) cast. to weld cast metal u must heat it up red hot then u can weld. so u used a esdilen (spelled really wrong u know the gas stuff) torch and when it was red hot my dad welded it. then we grided it down smooth. i said pinion gear bc most people know wat is ment by that.
Shaun
ps they dont make 3.40's anymore that was wat i was told anyway
Old Feb 27, 2002 | 06:25 PM
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Correct, they don't make 3.40's but 3.45's are available.
Miles
www.9bolt.com
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
