is it the U joint?
Old Feb 24, 2002 | 05:35 PM
JeffC1500TBI's Avatar
is it the U joint?
ok.. I'm at a loss now.. here's the story... I bought my truck a few years ago '88 C1500 350 TBI... it had like a clunk to it when you'd let off the brakes after a stop .. or sometimes it wouldn't do it t'ill you went to accelerate.. it turned out to be a broken tranny mount.. ok so that was replaced and the problem was gone.. a few weeks later it starts doing it again.. also at some point the ujoints where replaced.. I don't recall when I had that done though.. then the bottom end goes in the engine .. as some of you know... so now I have my nice fresh engine in along with new tranny mount again(because I bought the energy suspension engine/tranny mount kit).. everything is nice and tight on the tranny.. but I still get that dam kick when I let off the brakes.. I noticed if I stop hard and the truck kicks back when I stop it won't do it when I let off the brakes.. also if I stop and while holding the brakes I put it in newtral it will make that kick sound /feeling.. you actual feel it.. really seems like a driveline thing.. if I go from reverse to drive I don't get a big clunk like you would when a u joint was worn.. I know the u joints I have aren't greasable because they are gm replacments.. is there anyway of checking the u joints visually??? or anyone have an idea wheather it is a bad u joint??
thanks
Old Feb 24, 2002 | 06:17 PM
u r sofa king we tah did's Avatar
grab ahold of the driveshaft, try to rotate it, and see if it has any play in it at all. it shouldnt have any at either end.
Old Feb 24, 2002 | 06:44 PM
k.. I'll check that tomorrow nite.. I thought there was suppose to be some play.. between the tranny, the ujoints, the gears in the rear..
Old Feb 24, 2002 | 11:20 PM
jaymz's Avatar
OK it seems that you have a VERY common problem,I have the same one on my 92 c1500 excab.It looks like you have a standard cab and if it is not your u-joints,try installing urethane bumpers on the overload spring in place of the anti squeak discs.This will hold the axle from windeing up and binding the drive shaft when you stop. Vary the thickness of the bushings untill you find a comfortable medium. Hope this helps
Jaymz
Old Feb 25, 2002 | 07:14 AM
Jaymz
hmm.. ok.. if I lift up and down and the rear end I can't seem to get it to do it though.. these bumpers something you get at a spring shop?
Old Feb 25, 2002 | 01:08 PM
jaymz's Avatar
The axel only seems to wind when you are braking,this is a hard thing to simulate. If you see the holes that removing the plastic dics exposes this is whare you install the bumpers.I used energy suspension traction bar bumpers that I cut down.What you are doing is increasing the spring rate and locating the axel better.
Ed1LE
Sep 30, 2018 09:14 AM
Thirdgen89GTA
Oct 19, 2015 09:27 AM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
bubbaz28
Sep 18, 2015 02:09 PM
