Anyone have a TH400 in there firebird??
Old Mar 5, 2002 | 05:02 PM
CR-SuperChevy's Avatar
yeah its really complex to what im doing but i wanna know if anyones got one in their car?
Old Mar 5, 2002 | 08:52 PM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
It is not hard at all. Spohn makes the crossmember and then you just have to have the driveshaft altered. I just had a new one made since it is connecting to a 9" rear end.
The 400 is the one of the strongest trannys you can get. If you plan on going ***** out racing (cheap) then it is the way to go. If you have the cash, go with a 200R4. Art Carr has those behind alot of 8-9 sec GN's. The gear ratio is superior to the 700R4 so you do not drop out of your powerband.
Old Mar 5, 2002 | 11:04 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Buying the Spohn torque arm assembly is the best way to go but you don't need to go that far if you can't afford it.
Buy the B&M TH400 swap kit for third gens. TCI, Hurst and a few others make a similar kit. It includes a new tranny crossmember, torque arm mounting bracket and all the other parts required to do the swap.
You'll still need to get a new driveshaft made up since the TH400 is longer than the 700R4, TH350 or T5 trannys. You'll need a slip yoke for a TH400 since the output shaft is larger than those trannys also.
A TH350 is a much easier swap. The TH400 can take a lot more abuse and is cheaper to build. The TH400 is also a better designed tranny.
I ran a TH350 in my race car for 2 years and only went with a TH400 this winter because I also went with a transbrake. The TH400 was cheaper to beef up than the TH350 would have been.
Old Mar 6, 2002 | 10:37 AM
yeah I got a custom rebuilt Chevy 350, moly rings, comp cam268, comp cam lifters, heavy duty truckX rods, TH400/w Shift Kit not much but its my baby. Original Car. V6 TBI yeah baby
Old Mar 6, 2002 | 12:32 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
I had a TH400 in the camaro, its not a big deal to swap in. B&M change over kit is the only way to fly although I fabricated all the stuff my self except the drivshaft. Your setup is close to what I have/had in the firebird I had a TH350 behind the 355 and it worked great but I went with a 700r4 just for the advantages of its 1st and 4th gear.
jtwoods4
Sep 3, 2015 05:39 PM
Formula_88AE
Sep 3, 2015 01:47 PM
jtwoods4
Sep 3, 2015 10:19 AM
90formulaVortec
Sep 3, 2015 09:26 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
