How much torque can the 93+ stock 6 spds handle?
Old Mar 6, 2002 | 11:18 PM
Ghour_Demon's Avatar
Im trying to figure out what would be the most powerful crate motor i could swap without having to replace the transmission,
My current guess is that they should be able to hold 400 > 450 ft/lbs, and up to 500hp but thats just a guess.
Opinions needed........
Old Mar 6, 2002 | 11:34 PM
iroc22's Avatar
Well they use the same unit behind the Viper V10 if I am not mistaken.
Old Mar 7, 2002 | 11:31 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
I don't remember what the 93 units are rated for, but the 94-97 ones are rated for around 450ft-lbs (though I know plenty of people have put more through).
Old Mar 8, 2002 | 07:16 AM
IRACE87's Avatar
Car: 1987 IROC-Z
Engine: 383 HSR, AFR 190
For 93 you had different T56 with different torque rattimg, the M28 has 360 ft/lbs it has a 3.36 first gear and came with the 2.73 axle, the M29 has 400 ft/lbs it has a 2.97 first gear and came with the 3.23 axle and finally the MM6 that has a 2.66 first gear and is rated at 440 ft/lbs.
I'm not sure if the MM6 was available in 93, but I know that it was the only one available from 94 +.
Old Mar 12, 2002 | 07:09 PM
Yarnboy's Avatar
How can you tell the '93 tranny's apart? Can you tell by the numbers?
sweet_87_iroc
Sep 25, 2015 10:01 PM
InfinityShade
Aug 22, 2015 08:00 PM
sreZ28
Aug 14, 2015 07:48 PM
Dquickshift
Aug 12, 2015 06:21 PM
