Bad vibrations when I shift into overdrive
Old Mar 9, 2002 | 12:25 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
Last night was the first time in a while that I've actually put the tranny into overdrive. When I did the car started vibrating bad. When I shifted it back into normal drive it went away. I tried it once more and again the same thing. What could be causeing it to vibrate like this in overdrive?
Old Mar 9, 2002 | 05:58 PM
transfixleo's Avatar
Most likely an engine missfire. While it is also possible that you have a TCC shudder it would be best to start at the engine. You can check it by using a Vacuum Gauge. When the problem occurs look at the Gauge, if it all of a sudden starts bouncing around (the needle that is) then you have a missfire. If not then it is TCC. You can also do this with a scanner looking for O2 to fix when problem occurs.
Old Mar 11, 2002 | 09:53 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
What is a TCC? To use a vacum guage doesn't the vehicle have to be in park? It would only start to vibrate when I shifted it from normal drive to overdrive when I noticed it start to vibrate I shifted it back to normal drive and it went away, this is all while driving down the street.
Old Mar 11, 2002 | 10:37 AM
CODY BEHNKE's Avatar
The reason a missfire is felt in OD is because the torque converter locks up and eliminates the " fluid dampner " made by the fluid in the Torque converter.
Old Mar 11, 2002 | 11:45 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
What would cause it to missfire? I would beable to detect a missfire just by hooking up a vacum guage with the car running in park?
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
tonys91rs
Sep 2, 2015 07:07 PM
greenyone
Sep 2, 2015 03:39 PM
RyanJB
Sep 2, 2015 01:27 PM
