Megashifter Directions
Old Mar 9, 2002 | 02:10 PM
BG87z's Avatar
Car: 1987 IROC-Z
Engine: Carbed 355
Transmission: TH-350
OK guys i installed my B&M megashifter a while ago witht the transmission out so i did not bother to put the adapters on the tranny for the shifter cable. well i cant find the directions any where could some one post them or send them to me. thanks soo much guys
Old Mar 10, 2002 | 03:47 PM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
assuming you still have all the parts, take the factory brackets off of the tranny,put the spacers under the new brakets and arrange them about the same as the same as the original were. fix the cable bracket to the rear side of the shifter and leave it. set the cable on the tranny with a nut on each side of the bracket and the "threaded nub" in the hinge part on the selector lever,...this is all occuring under the car,don't put the cotter pin through the nub yet (you may have to tighten or loosen it still) don't tighten the two nuts with a wrench yet,.....most of the fine tuning will be done by hand. speaking of fine tuning,the nub is to "fine tune" the two nuts are to "coarse tune" the control of the shift lever,kind of like doing the derailrs on your mountain bike. with the nub disconnected from the selector,move the shifter all the way down to first gear position,check to see if the nub easilly inserts into the selector. disconnect the nub (this is why you don't put the cotter pin in,you may have to do this several times) move the shifter back up to park,same thing,the nub should fit easilly into the selector lever on the tranny when it and the shifter is in park,repeat again,1st on the tranny and the shifter. don't connect the cotter pin and shift with cable connected until both first and park insert easilly. btw I think the most farthest foward hole is for the 700r4,check with B&M first,also you need to remove the 4-speed pin from the rear of your shifter,it's held in with a snap ring,it let's you move it into first. if you use common sense when you first connect the cable,it shouldn't take you more than 5 minutes to tune in. not to loose,not to tight...happy ratchet shifting!
Old Mar 10, 2002 | 06:38 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
B&M might even mail you a copy (email or u.s. mail) of the instructions if you call 'em and ask... website's http://www.bmracing.com ; they must have a phone number up there somewhere.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
gixxer92
May 18, 2017 11:20 AM
efiguy
Sep 27, 2015 01:30 PM
Lmancha96
Sep 25, 2015 08:11 PM
