Any tips or tricks for 700-r4 install?
Old Mar 11, 2002 | 03:55 PM
Eggplant Jeff's Avatar
I ordered my 700-r4 from pro-built a couple weeks ago, it should get here this week or next (I can't wait!), which means one of the upcoming weekends I'll be doing a tranny swap. Currently I have a worn-out 700-r4.
I was wondering if anyone had any tips, tricks, or advice that will make this swap easier? I've helped install a T56 in a thirdgen but the manual tranny is a lot narrower, without the big pan on the bottom. Also if possible I don't want to have to remove the interior to get access to the top of the tranny.
Thanks in advance!
Old Mar 11, 2002 | 09:28 PM
Dex's Avatar
Dex
man I just started to pull my 700 r4 out and i got the torque converter unbolted and 3 bellhousing bolts and the starter off in an hour i could pull the trans out of my old ranger in 45min
this is one of the only things i absoulty hate about this car
Old Mar 12, 2002 | 12:52 PM
82camaro's Avatar
Car: 82 camaro SC
long extensions and a swivel socket for the bellhousing bolts
Old Mar 12, 2002 | 03:28 PM
powermite's Avatar
Car: Transam
Engine: ZZ4,Holley Stealth Ram,Commander 950
Guys,
Thers no need to take the starter off.As 82 Camaro says,the top two bolts are best got at with a very long extension running from the tail of the transmission
PM
Old Mar 13, 2002 | 10:23 PM
AirN_2_TA's Avatar
ah there is no need for the long extensions and swivels for the top bellhousing bolts......i got mine off from inside the engine bay with a good ol' box end wrench......
Old Mar 14, 2002 | 03:23 PM
SIMON HOLTBY's Avatar
If it wont shift into second gear like mine did not you have not got the fluid level correct most likely too low. If you then put too much fluid in the gear shifts are also strange, did that as well.
It is difficult getting fluid out the tranny (no drain plug). I spent hours trying to work something out. Sucking, syphoning did not work as the oil is too thick. Then I noticed my gallon container of hand cleaner Swarfega or similar it has a hand pump on the top. Removed it cleaned it and connected a pipe on the bottom and it could pump about a pint per minute if required.
Considering how much oil is in the tranny it is surprising how much difference a pint of oil makes to the gear change.
Simon
rocn7roc
Sep 21, 2021 02:16 PM
Mickeyruder
Sep 2, 2015 02:45 PM
theshackle
Aug 22, 2015 06:52 PM
BurlyChev
Aug 22, 2015 11:42 AM
Hello, Michael
Aug 20, 2015 03:19 PM
