TH-350, TH-400, and 700-R4
Old Mar 11, 2002 | 11:06 PM
84Camaro305's Avatar
Car: 1989 Pontiac Firebird
Engine: 305 TBI
I'm not sure if I should rebuild my 700-R4, take a transmission from a 4th gen camaro (no clue what those are), get a TH-350, or TH-400. Any suggestions? I'm trying to not spend a lot of money on the transmission, but still get a good transmission that won't crap out on me. It seems that rebuilding my 700-R4 is going to cost a lot and just put me back w/ the same crap I had before. A friend said I could get a TH-350 for $500, but another friend said not to do it because the TH-350's only have 3 gears. So, how many gears does each have, about how much would each cost to buy, and which would you suggest that I get?
Old Mar 12, 2002 | 12:34 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
What kind of driving are you intending to do? A 700R4 is a good street tranny but makes a poor drag race tranny. It has a very low first gear and an overdrive.
The TH350 and TH400 are 3 speeds. No overdrive. The TH350 is a light duty tranny that can easily be built up. There are millions of them all over the country. The TH400 is a heavier and much stronger built tranny. It's usually the tranny of choice behind high HP cars. It takes very little to beef it up. It takes more HP to spin a TH400 than it does a TH350.
Old Mar 12, 2002 | 12:54 AM
Engine: 305 TBI
Planning on street driving w/ either a rebuilt 305 or an LT1 as an engine. Both would end up most likely around 300 hp (somewhat below or above that w/ those engines respectively).
Old Mar 12, 2002 | 07:20 AM
transfixleo's Avatar
All things considered I would probably stick with the 700 but perhaps a later core and have it built properly. In the long run it will be cheaper and not compromise with no O/D.
Old Mar 12, 2002 | 07:51 AM
82camaro's Avatar
Car: 82 camaro SC
You will miss the overdrive down the highway if you get rid of the 700r4. Drive around a few days just using D instead of OD on the shifter--especially on the highway. The rpms will be even higher than that since a th350/400 won't have a lock-up converter(unless you get the th350c).
Old Apr 7, 2014 | 02:18 PM
Vince Grossmann's Avatar
Re: TH-350, TH-400, and 700-R4
anyone ever hear of the 4L80E??? best of both worlds right there. nice over drive gear 4 speed. and can handle a S*** ton of HP. im might buy one myself right now haha.
Old Apr 7, 2014 | 06:34 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
https://www.thirdgen.org/forums/tech...formation.html
Learn to use the button.
Plenty have swapped it in
https://www.thirdgen.org/forums/tran...l80e-swap.html
Also ;
not good form to bring up 14 year old ( 03-12-2002 ) posts .
Start a new one if you have a question
TexasMaro
Sep 15, 2015 06:50 PM
Brendan
Feb 20, 2003 02:14 PM
ADMZ24
Aftermarket Product Review
Apr 26, 2001 02:40 PM
kidpunkr
Jul 28, 2000 07:52 AM
