Which Gears?
Old Mar 12, 2002 | 09:50 PM
Joshua Leslie's Avatar
Which Gears?
Hello
I have an 89 T/A
currently, the car has a very mild cam, gives out aroud4400rpm, but pulls awesome till then, and has 2.73 gears, a 700r4, with stock converter.
next week, I am putting a Corvette converter in it.
and in 1 month, I am having the gears changed.
What gears would be the best, I am also going to run either a comp cams x/e 262 or 268, so I will be basing the gears from the cam.
The engine redlines at 5500rpm, im afraid to push it any higher than that, as the pistons are stock.
I will proly also do some at home porting on the heads.
What gears would yall recomend?
I was thinking 3.73, I am also having a limited slip unit installed.
Old Mar 13, 2002 | 02:23 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
If you get a new cam that makes power to 5500 , 3:73s would be the limit. That's what I would go with.
Old Mar 14, 2002 | 05:35 PM
cp87GTA's Avatar
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Axle/Gears: 9" ford 5.67
Re: Which Gears?
Originally posted by Joshua Leslie
Hello
I have an 89 T/A
Your pressent setup will suffer quite a bit with the 373s untill the cam change. I believe you'll have a LOT of grinding to do on the heads, intake, runners, and plenum. A xe268 will work real good if all of that is done. Don't forget the stall converter. The 268 won't like a stock converter very well. What stall is the vette converter?
Old Mar 14, 2002 | 06:23 PM
Car: 99 Formula
Axle/Gears: 342
Re: Re: Which Gears?
A 268 should do fine with a stock converter, especially with 3:73s and the deep first gear of the 700R4. That cam starts power at 1600 which isn't that high with low gears. That's what I was recommended to get with a stock converter.
Old Mar 15, 2002 | 05:23 PM
cp87GTA's Avatar
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Re: Re: Re: Which Gears?
It depends, if you want a bear or a cub. I like the bear, myself.
Old Mar 15, 2002 | 06:08 PM
AfootVoyager's Avatar
just my thought and opinion...i've got 3.73's on my stock motored 85 T/A...and they are awesome...!!!
Old Mar 15, 2002 | 07:08 PM
82camaro's Avatar
Car: 82 camaro SC
If you go with 3.73's a stock converter will be ok with that cam. A higher stalling converter with 3.73's will probably just give you wheel spin off the line.
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
