help just a bad luck person
Old Mar 16, 2002 | 08:41 AM
bklucas12's Avatar
Im just a little upset now, stuff keeps going wrong on my car with every month, When I was going to virgina from tennessee on spring break I was going at normal speed, decided I wanted some gas milage so I put it in 5th, went into the gear fine, well I thought released the clutch, pushed the gas and it just reved, went back into 4th, tried the same thing, it looks like my overdrive is NOT working, at this point I am almost crying cause I pay for everything myself and I know I wont be able to afford a new transmission, am I correct in assuming that my transmission is gone? all gears work fine except my overdrive gear... thanks for all the help
A kid who is almost had it with 3rd gen's
Old Mar 16, 2002 | 12:53 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Do you have the same problem in the lower gears?
When was the last time you replaced the clutch?
Old Mar 16, 2002 | 01:40 PM
bklucas12's Avatar
Never replaced the clutch.... I bought it with the 350 already installed with the factory t5, but my question is, is my transmission fu*ked or is it something else here is the gist
All 4 gears plus reverse works... overdrive does not work at all, just sits and reves in 5th... I have no money to fix it either way I just want to know what the deal is before I start looking for another job to pay for a transmisson or clutch, I will put them in myself thats not a problem... so what do you guys think it is? bad clutch or just a bad transmission... thanks for all the help
Old Mar 18, 2002 | 10:06 AM
bklucas12's Avatar
anyone know if my transmisson is going out? or is it my clutch, problem is overdrive just reves in gear, all other gears work fine...
thanks
Old Mar 18, 2002 | 11:03 PM
mechanicalmehem's Avatar
well, i am thinking one of two things, either the shift linkage for fifth isnt working(broke) or the gear is gone(destroyed)
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
dbrochard
Oct 3, 2015 12:43 PM
webeeZ28
Sep 14, 2015 12:00 PM
Stryker412
Sep 7, 2015 09:11 AM
