700R4 Trans Removal
Old Mar 16, 2002 | 04:54 PM
FJK's Avatar
FJK
700R4 Trans Removal
When removing the trans from an 88 GTA, is it necessary to remove the entire torque arm from the vehicle, or just disconnect it from the rear of the trans? If complete torque arm removal is required, is it necessary to remove the rear springs to prevent axle housing shift or binding? Rear spring removal is called for in the factory shop manual.
Comments, suggestions please. FJK
Old Mar 16, 2002 | 08:38 PM
Joshua Leslie's Avatar
when I did mine in my 89, I just unbolted the torque arm from the tranny, but be careful, that thing is under tension and it will snap up, so when you take that last bolt out, keep a firm hold on it, and let it go slowly!
camaro11j
Sep 19, 2018 08:49 AM
Reddeath210
Oct 6, 2015 08:20 AM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
Leggman1
Aug 6, 2015 04:15 AM
