700R-4 Upshifting at high RPMS
Old Mar 17, 2002 | 03:05 AM
JWS's Avatar
JWS
I have an 89 IROC with a 350TPI and 700R-4. The trans all of the sudden will not upshift until about 5000 RPM in each gear. Fluid level and condition are perfect. Fluid and filter were changed less than 10,000 miles ago. What could cause this?
joe
Old Mar 17, 2002 | 03:59 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Stuck throttle valve?
Old Mar 17, 2002 | 10:56 AM
JWS's Avatar
JWS
how hard is it to get to the throttle valve and where is it? are there any vacuum lines hooked up to this transmission?
Old Mar 17, 2002 | 03:52 PM
Pro Built Automatics's Avatar
Take out the governor to see if the gear is broken or stripped, this is quite common.
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Stryker412
Sep 7, 2015 09:11 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
