2.73 to 3.23
Old Mar 17, 2002 | 08:57 PM
L.I.N.Y.92CAMARO's Avatar
2.73 to 3.23
How much would my speedometer be off if i changed my rear gears to 3.23?
Old Mar 18, 2002 | 12:02 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Well at lower speeds it will be less off. You can figure it out using this simple formula:
Old gear ratio/New gear ration X speed speedo says
2.73/3.23*60MPH = 51 MPH
So that means when your speedo says 60 MPH your real speed will be 51 MPH
here are a few more:
2.73/3.23*20MPH =17 MPH
2.73/3.23*40MPH =34 MPH
2.73/3.23*80MPH =67.5 MPH
2.73/3.23*100MPH = 84.5 MPH
Old Mar 19, 2002 | 05:46 AM
88transam5.0's Avatar
Hi, I don't know if your wheels are 17's which mine are 45/245/17 I did this swap a while back from 2.73 to 3.23 and if your present gear combo is 17T/38T then you will need a driven gear 44T. But if you have 16's wheel then this won't help.
KO1
16
Oct 15, 2015 05:00 PM
Numbah-1
Sep 12, 2015 08:57 PM
64Chief
Sep 12, 2015 08:05 AM
john204481
Sep 7, 2015 03:22 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
