Do you have to resurface a brand new flywheel??
Old Mar 18, 2002 | 12:50 PM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
I think it explains itself.
Old Mar 18, 2002 | 05:55 PM
ede's Avatar
ede
no, but it wouldn't hurt if you did, wouldn't help much either
Old Mar 19, 2002 | 07:08 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
If it's a new flywheel you won't need to resurface it and I don't think it would be a good idea to resurface it, especially on a Camaro with non-adjustable clutch linkage.
Old Mar 20, 2002 | 05:31 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
yeah, because after resurfacing it too many times, you'll either need a new flywheel or shims to act as a spacer behind the flywheel
funny, but mine was cut serveral times and it works great
it was cut twice since i bought the car (dont ask), and *** knows how many clutches the previous 2 owners went through with 160,000 miles
maybe mines not original
Old Mar 20, 2002 | 08:59 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
Most new flywheels are not very flat. Ever new one I've gotten I've taken and had them turned "true". Clutch chatter is a bitch.
Old Mar 21, 2002 | 07:37 AM
Car: 1991 Firebird
Engine: 427 LSX
What brands did you have? This one I bought looks pretty good. Mcleod
Old Mar 21, 2002 | 08:05 AM
99Hawk120's Avatar
All were GM .
Old Mar 23, 2002 | 06:06 PM
cfabe's Avatar
I'm surprised you have had chatter problems with gm flywheels. I just bought a new gm one for my t56 swap, and wasnt planning on having it turned. They make replacement parts the same way as production parts, I'd assume, and Im sure they didnt have 4th gens coming off the assy line with clutch chatter problems. I certianly hope i dont have to pull it all back out to get turned.
Old Mar 25, 2002 | 08:05 AM
99Hawk120's Avatar
Keep in mind I also got a GM flywheel that the crank bolt holes were misdrilled, so it could just be my rotten luck.
Old Mar 26, 2002 | 01:31 PM
MIG-29's Avatar
Car: 1987 Camaro
Engine: 1986 350
Transmission: T-5 NWC
1- you don't have to resurface.
2- the old style, for the 2pc. rear main seal, has an extra hole that must be positioned properly, the way i've seen it out and the same i did was the extra hole blocked by the flat side of the crankshaft, wich means...
the support is kind'a weird half moon shape, the extra hole on the flywheel goes right in between (centered) of the 4 threaded holes located on that weird looking half moon shape.
no chatter nor any abnormality.
Fernando
Old Mar 26, 2002 | 01:34 PM
99Hawk120's Avatar
I don't know if that post was directed at me or not.
The GM flywheel I got that was misdrilled was an LT1 flywheel, for a one piece crank. Four of the holes matched up and two did not. The two that did not match were the ones on either side of the hole for the flywheel dowel.
I had them ship me a replacement and the holes were drilled correctly.
It was not an issue of installer error. One piece RMS flywheels only go on one way.
And neither flywheel was flat.
Old Mar 26, 2002 | 01:44 PM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
What if you have surface rust that has formed on the mating surface?
Old Mar 26, 2002 | 02:05 PM
99Hawk120's Avatar
If you can remove the surface rust with steel wool you should be okay. Otherwise you'll have to resurface. It depends on how much rust there is.
mr z28
Exterior Parts for Sale
Dec 14, 2015 05:14 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
