9 bolt question about swapping gears
Old Mar 19, 2002 | 11:26 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
I've got a car w/ the BW 9bolt and the poopy 2.77 gears. I've found a used set of 3.27 gears for cheap, but will it work? I mean for example, you can not swap 3.23 gears into a 2.73 rear in a 10 bolt because of the different carriers. Is this an issue with the 9 bolt also? Or will these gears work fine?
Old Mar 19, 2002 | 11:42 PM
Momar's Avatar
Yup, it is an issue. Like a 445 dollar issue if I recall correctly unless you can find a used carrier. Go to www.9bolt.com
Old Mar 20, 2002 | 06:19 PM
Eightyninef's Avatar
I have a used set of 3:27's and a matching carrier. $60 for both.
larryburd@mail.com
hectre13
Dec 11, 2023 08:14 AM
1984HO
Mar 19, 2021 11:59 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
