Question about T5's
Old Mar 24, 2002 | 09:54 PM
khellendros's Avatar
Question about T5's
I was wondering if you can use any type of T5 Transmission for a 305 block or a 350 block for a pontiac firebird. I am dropping in the engine, and i need to find the transmission. Will a Ford T5 transmission work off a mustang, or off a chevy s10? Which is the better pick? Should i stick with a Camaro/Firebird T5? Thanks guys
Old Mar 24, 2002 | 10:05 PM
87RS402's Avatar
No, it has to be a thirdgen T-5.
Old Mar 24, 2002 | 10:06 PM
ok, so i have to put a camaro/firebird T5 into it. Is there anything else better then a T5 that might hold up better under heavy shifting? Thanks
Old Mar 24, 2002 | 11:15 PM
87RS402's Avatar
Pick your poison:
T-56 (stock from a 4th gen or aftermarket)
Tremec 3550
Tremec TKO
Old Mar 24, 2002 | 11:19 PM
D-ROK 420's Avatar
t-5
What is the differeence between the two Tremec transmissions?
Old Mar 25, 2002 | 01:22 AM
87RS402's Avatar
About 100 lbs torque capacity, the TKO is rated for 550 and the 3550 is rated for 450, the gear ratios are the same for both boxes.
Well that and about $200-$300
Old Mar 25, 2002 | 06:20 AM
Arianboy's Avatar
You could always go retro and throw in a M-22 I'm all about the "Rock Cruser"!!:hail:
fasteddi
Sep 10, 2015 09:32 AM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
