T-5 second and third gear grind, in morning..
Old Mar 26, 2002 | 04:47 PM
irocnroll89's Avatar
From: previously OKINAWA JAPAN,georgia, now new england
Car: 1989 IROC--1989 T/A
Engine: 5.7 TPI in both
Transmission: W/C T-5 in both
Axle/Gears: B/W 3.27 in both
When i first drive the car in the morning, pushing the clutch in, i still have a grinding into second and third gear. I am shiftting regularly, not ramming or power shifting. Do you think this is a "cold"" clutch? I also have had a recurring valve cover/intake leak allowing oil to get down on the back of the motor. It does clear up after 5-10 miles "warm up". thanks a bunch , shaggy
Also it is a low milage centerforce clutch, and the t-56 slave cylinder assy.
Old Mar 28, 2002 | 08:27 PM
ttt
Old Mar 28, 2002 | 09:40 PM
Tom84L69's Avatar
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
it could be synchros or a worn clutch disc.
db057
Apr 28, 2019 07:45 AM
Jorlain
Oct 8, 2015 01:57 AM
88rscamar0
Sep 23, 2015 09:08 PM
Formula_88AE
Sep 3, 2015 01:47 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
