How can you help out a 700R4?
Old Mar 27, 2002 | 04:22 PM
brian89transam's Avatar
Over a year ago my tranny went out and local shop installed a rebuilt one (i'm not sure where it's from.) I did notice the shift points were different than the old one though. Anyways, the warranty has now run out, and I am wondering what I can do to make it shift a little firmer and last longer.
I'm not sure about shift kits. I've heard they can be bad on transmissions.
I've seen several people with Corvette Servo listed in their sigs. How do they help?
I've thought about a B&M trans cooler, but I'm not sure if I really need one or not.
I figure I might as well change the fluid with the B&M Trick Shift stuff too.
Just looking for some comments and information. Thanks.
Old Mar 27, 2002 | 06:25 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
Get a hold of probuilt at www.pro-built.net. Dana recommends Trans Go all the way and this will actually help your trans by actually fixing all of the problems associated with the 700R4 while firming up the shifts. Also I recommend the B&M trans super cooler very strong and almost unbreakable. Also stay away from the trick shift very bad idea, ONLY use Dextron III. Dana recommends Mobile Dextro III not mobil1. The corvette servo provides more clamping force to the 2-4 band ='s better shifts.Good Luck!!
Old Mar 27, 2002 | 11:25 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I agree, call Dana, tell him what you've got and what you expect to do. Then do everything he tells you to do.
He'll probably tell you to use AMSOIL ATF if you ask.
Old Mar 28, 2002 | 11:21 AM
thanks a lot. it's good to see someone from IOWA around here.
Old Mar 28, 2002 | 06:17 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
My tranny mechanic (who has been working on trannys for 30 something years) won't touch anything from B&M with a 10 ft pole. When I asked him about their shiftkits, he flattly refused to have anything to do with it. He only puts in Transgo.
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
