no torque converter cover....big deal??? safe??
Old Mar 28, 2002 | 08:53 PM
350turbo411's Avatar
Car: 1983 Z28 Clone
Transmission: TH350
hey guys, i have a t350.....jerks pretty hard when i put it in gear........and shakes the car too much to drive......car runs like its on 7 cylinders when in gear.....and it takes 4 or 5 seconds for the reverse to kick in.......the tranny fluid is clear??? who makes clear tranny fluid ????
ok but..i dont have a torque converter cover on my tranny?? it it ok to run it like this...????? i dont have a repllacement
rob
Old Mar 28, 2002 | 09:22 PM
82camaro's Avatar
Car: 82 camaro SC
Running rough while it's in gear is probably not related to the tranny. In gear it will idle slower. Clear tranny fluid? maybe it's not on the stick at all. If someone even made clear tranny fluid, it wouldn't stay clear very long anyway. Change the fluid and fix the rough idle. No cover isn't safe if you work under it while it's running. Could also get rocks and dirt and stuff up in there--that would be bad. Get a junkyard cover if nothing else.
Old Mar 28, 2002 | 09:31 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
Sometimes the fluid is hard to see if it's really clean. (Providing there's some on the stick.)
I've been running without a TC cover for a couple months and it makes me nervous. I'm trying to get my hands on one as soon as possible 'cause I know I'm going to get called on it by the tech guys at the track one of these times.
Old Mar 29, 2002 | 10:10 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
Most guys I know don't use a cover. In fact, I don't even use one. The reason is that it lets cool air up in there to help keep the tranny fluid, converter and trans a little cooler. Even if it's just 10 or 15 degrees it's worth it to me because I have a 3200 non lock-up converter that I use on the street. They tend to build alot of heat.
I don't know of any clear fluid. You should probably change fluid and make sure it's full. Even if it's clean it should still be red.
Old Mar 29, 2002 | 10:15 PM
Car: 1983 Z28 Clone
Transmission: TH350
yeah ya know .i looked around the pan..and its dripping ..(the usual drip a day) clear fluid..looked at the dip and its clear!!!!
hmm.......ill leave it off......then.....
i've never drivin a camaro......i own a monte carlo....so......the car is getting ready to go on the road....april 12th.....i cant wait..but....i'm defanately going to get that tranny fluid changed............................
just have to figure out why my car idles at like 500 in gear ..and shakes like a funny car...............1200rpm in park...
but... thanks...
i'm leaving it off
sorry for spelling its friday ..and i'm a little juiced..
rob
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
jklein337
Sep 19, 2018 06:23 PM
xxx3man`
Sep 23, 2015 10:37 PM
dyeager535
Aug 28, 2015 08:10 AM
gwade12
Aug 8, 2015 08:17 AM
