Need help with Speedo gears
Old Mar 30, 2002 | 03:41 AM
Buisson 91TPIZ28&91B4C's Avatar
From: Louisville,KY Crawfordville (Tallahassee), FL
The vss drive gear for my 3.23 rear is light green, Which color\tooth gear do I need for a 3.73 rear???
Old Mar 30, 2002 | 11:27 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Go to www.700r4.com/ and click on the speedo calculator, enter your tire size and new ratio and it will tell you what you need. You will need the larger offset housing sleve and probably a 43 tooth driven gear, but I dont know the part numbers for the VSS.
SSC
Old Mar 30, 2002 | 11:02 PM
Omar's Avatar
Search Feature. Use it.
GTAman
Jul 3, 2024 07:29 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
88rscamar0
Sep 23, 2015 09:08 PM
andy74
Sep 3, 2015 08:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
