5 Spd To 4 Speed Swap
Old Apr 3, 2002 | 12:14 AM
88IROCROB's Avatar
Have mild built 305 tpi 5 spd 88 iroc, friend recommended changing to 373 rear end w/ 4 speed and different prom...
any thoughts? i would prefer to keep veh semi-original and rebuild the 5 speed...
thanks, rob
88 iroc conv 305 tpi
Old Apr 3, 2002 | 08:12 AM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
Do what you want. If you need to hear someone say you should rebuild the 5 speed...well then, here goes:
Rebuild the 5 speed and don't listen to your screwball friend.
HTH,
Clem
Old Apr 3, 2002 | 08:16 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Losing overdrive & lowering the rear ratio does not make any sense. Rebuild the 5 speed.
Old Apr 3, 2002 | 06:18 PM
MikeS's Avatar
I would not swap a five speed for a four. If anything else was going in there, it would be a T56.
Keith5
Aug 27, 2015 04:37 PM
cam-mike
Aug 24, 2015 07:23 AM
InfinityShade
Aug 22, 2015 08:00 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
