4 th gen trans without 1st
Old Apr 3, 2002 | 12:05 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
My friend had a 4 th gen with a LT1 on his lot for sale.
We took it out for a spin. When I looked at the console there was no 1st gear. it went 2, D, OD.
We brake torqued it, then took off. It shifted out of 1st automatically. This realy sucks. the car would be alot stronger if it would stay in 1st longer.
What kind of trans deal is this. Im not trying to sound stupid, but the only 4 th gens I have been in had either a 6 speed or the trans with 1, 2,D, and od on the console.
The car had a 150 mph speedo. I not sure what year, but it had the polished salad shooter wheels.
Old Apr 3, 2002 | 12:13 PM
BigRuss's Avatar
Go to this web site and try following the procedure there to get 1st gear:
http://www.fbody.com/tech/details.cgi?id=7
I haven't tried it or talked to anybody that's tried it, but it seems to be very straight forward and makes sense. Good luck!
Old Apr 3, 2002 | 12:22 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
thanks man. I will tell my friend about this. Why did gm set these cars up this way and other cars with the 1st in the console?
Old Apr 3, 2002 | 12:27 PM
BigRuss's Avatar
I'm not sure exactly why they did it. 2.73 ratio is an economic ratio anyway. Maybe they wanted to ensure it got good gas mileage by preventing you to go into 1st...
Old Apr 5, 2002 | 10:38 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
They don't allow you to manually shift into first gear because of noise polution. They found that traveling at X mph in first the car was too loud, so they disabled it. All you have to do is take the console off and remove the little plastic peice that stops you from sifting into first. Its a very simple mod.
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
Reddeath210
Oct 6, 2015 08:20 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
