t56 guys inside
Old Apr 8, 2002 | 04:41 AM
toosloz's Avatar
t56 guys inside
well...mine is in!!:lala:
got a few questions......
how'd you hook up the reverse lockout
if you used the spohn x member...did it rub on the bolt for the torque arm?
Old Apr 8, 2002 | 08:48 AM
Brian Shaughnessy's Avatar
Car: '89 Formula
Engine: 355 TPI
Axle/Gears: 3.70 9 bolt.
Reverse lockout is wired to the Hurst t-handle with the button I used... it also runs the line lock.
Spohn x member. Yeah, it will be close or rub the thru bolt for the exhaust/cat mount. Take that through bolt out and grind it just a bit to improve clearance. I found it best to use the ES tranny mount and USE the spacer plate that comes with it.
Old Apr 8, 2002 | 02:37 PM
xxwarrior36xx's Avatar
sorry...probably a dumb question but why would you want a reverse lock out?
Old Apr 8, 2002 | 02:44 PM
BigRuss's Avatar
Keeps you from sliding into reverse instead of 5th when you're going, say, 60 mph...
Old Apr 8, 2002 | 06:19 PM
m23haz's Avatar
Car: 91 Camaro Z28
Engine: 5.7 TPI
Did you guys put in a new 5spd consol shifter plate? How did it fit?
Old Apr 8, 2002 | 09:59 PM
ScreaminDeamin85Z's Avatar
i still havent hooked up the reverse lockout, its pretty hard to get past the solenoid when its not hooked up so i think i will leave it that way. whatever floats your boat. ive also read people wiring it so it engages only when the brake pedal is pressed.
Old Apr 9, 2002 | 01:20 AM
toosloz's Avatar
yea...i just did a few runs on it and it must be that exhaust bracket that is making the noise...tad annoying
i love it so far!!!...its a nice smooth tranny
jharrison5
Aug 19, 2015 05:53 PM
Street Lethal
Aug 14, 2015 08:25 PM
hokis
Aug 9, 2015 03:57 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
